How to get front lower?
Discussion in 'Suspension/Chassis' started by Gsalvob3, Jan 18, 2016.
  1. Gsalvob3
    Gsalvob3 Member
    Charlottesville Virginia
    1994 Toyota pickup ext cab
    I've got 2 inch drop spindles and lowered the torsion bars another 2 inches what's the easiest way to lower the front without doing a ball joint flip
  2. Gsalvob3
    Gsalvob3 Member
    I want to lower the front another 2 inches
    Mattyp902wd likes this.
  3. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Park the front tires in a pothole :evil:
    Seriously though, a ball joint flip is easy compared to some of the other options.
  4. Gsalvob3
    Gsalvob3 Member
    Anything else ? Other than ball joint flip
  5. aaron_sk
    aaron_sk Enthusiast
    Tacoma, WA
    '94 Regular cab
    Easy yes, but bumpsteer sucks, especially if you commute on the freeway. I'm about to flip mine back. Even with a brand new steering damper it's a PITA.
    @OP: You're looking at drop LCA's and that's about it unless you want to bag.
  6. jetas
    Drop arms.
  7. Gsalvob3
    Gsalvob3 Member
    I plan on c notching the rear and I'm trying to get the front a little lower cause the rear would be much lower than the front after the c notch
  8. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    How is bumpsteer affected differently from flipped ball joints vs drop lower arms?
  9. Gsalvob3
    Gsalvob3 Member
    I don't plan on bagging it I just want to get the front a little lower
  10. Gsalvob3
    Gsalvob3 Member
    Are there any cheap drop arms on eBay That anyone can suggest I use
  11. jetas
    Suspension components and cheap should never be sought after
  12. Gsalvob3
    Gsalvob3 Member
  13. Gsalvob3
    Gsalvob3 Member
    Okay can anyone suggest any kind of lowering control arms that they liked for around 200-300 dollars
  14. White Trash
    Eastern WA
    Summitracing.com carries 3" djm lower arms for right around $200
  15. Gsalvob3
    Gsalvob3 Member
  16. White Trash
    Eastern WA
    Those ball joint spacers you keep linking to are to lift a 4x4 not lower a 2x4.
  17. Gsalvob3
    Gsalvob3 Member
    Ok thanks for the input I think I'm going to get the djm lower control arms that should do the trick
  18. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    DJM lowering arms won't lower your truck. They only allow for proper alignment. I bought their 3"/4" kit and that is what the rep at DJM said. The instructions that you get with the kit tell you to loosen the torsion bars to achieve the 3" drop.
  19. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    they dont? really? if not thats bs, because i thought you could use those with the drop spindles to get you around 5" of drop.
  20. White Trash
    Eastern WA
    They do lower the suspension. If your torsion bars are at the same setting with stock arms and djm lower arms the djm setup will be 3" lower.
    If you have djm arms and you want to go back to stock height you'd have to crank the bars up far passed stock to get the height back.
