How much to shim?
Discussion in 'Suspension/Chassis' started by Mikerocosms, May 20, 2015.
  1. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    I have belltech 3" drop springs on the rear of my truck. Thing is the front of my truck still looks just a tad lower. I'd say about an inch or so.
    I was thinking about getting 1" blocks, but I understand anything around a 4" drop I would need to shim my axle so my driveshaft wont run perfectly straight. What degree of shims should I get? Or how would I figure that out?
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Measure the angle of the pinion flange at ride height.
    Measure the angle of the forward universal join in its vertical position at ride height. Now find the difference in angle and point the pi ion about 2* lower than perfectly in line to the trans to account for alight axle wrap while cruising.
  3. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    raise the torsions up a little bit
  4. White Trash
    Eastern WA
    Blasphemy! :lol:
  5. jetas
    Whats that mean? (Hillbilly voice)
  6. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
  7. raylcc
    raylcc Addict
    Denver, CO
    You mean those bar thingy's that you are supposed to remove as soon as you buy the truck? I'm pretty sure those and the spring packs in the back are just shipping stabilizers and are supposed to be taken out so the truck can go to its intended 6mm ride height. :p
