Hesitation
Discussion in 'Maintenance/Repair' started by craigdbl, Sep 25, 2012.
  1. craigdbl
    craigdbl Guest
    I have hesitation off the start. I add Sea Foam every other gas fillup to keep the injectors clean. At 20mph the throttle response is great if I step on it, I wish I could get that on the take off. any thoughts besides a vacuum leak?
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    timming.check dist. position.
  3. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    I second that
  4. 87jdmtruck
    87jdmtruck Member
    San Diego, CA!
    1987 Toyota Pickup
    I had the same problem when I bought my truck. You want to replace your fuel filter which is like $15, which should help you with the problem! It won't respond fast, but give it about 3 days to fully stop!
  5. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    cud be both! timing or fuel issue
