Hey toy lovers I need help with my lights My low beams don't work only my brights I did everything to see if it would work but I can't find the solution.before they used to work but they slowly Started to act up by not turning on right away it would take time for Them to on. I checked the relay all fuses the bulbs and also the whole Piece on the steering wheel can someone pls help me I might get a ticket One day for my brights being on thankyou
If you haven't inspected the wires or connections I'd start there and even the headlights themselves can act up if there cheap ones ...double check your relays and a multi meter is your best friend when it comes to wires see if your getting 12volts on the low beam circuit at the headlight connections also check your harness that runs across the radiator for cuts or melts
I am having the same issue. The low beams have never worked since I bought the truck. The relay clicks, and the high beams work. I don't see any burnt spots along the wiring...I even replaced the bulbs/lights themselves incase it was a defect. Any thoughts?
