I have been trying to find a diagram of the fuse block under the hood without much luck. I found the diagram for the one under the dash. Can some one post a diagram or a labled picture of it please? It would be much appreciated.
1-7.5 Amp Spare Fuse 2-15 Amp Spare Fuse 3-15 Amp (Pick Up) or 20 Amp (4Runner) Rear Window Defogger 4-15 Amp Instrument Panel Lights, Side Markers, License Lights, Parking Lights, Taillights, Deck Lights, A/T Shift Position Lights(1984 2WD), Rear Defog Indicator Light(1984-1985 2WD) 5-15 Amp EFI Control System, EFI Main(1984 2WD) 6-15 Amp Radio, Clock & Cig Lighter, PWR Antenna & Cassette Player, PWR Mirrors(1987) 7-15 Amp Wipers & Washers, Cruise Control, A/T Overdrive Solenoid(2WD), A/T Shift Position Indicator Light(1984) 8-15 Amp Back-up Lights, Gauges & Warning Lights, Alternator & Fuel Cut Solenoid(1984-85), Turn Signal LIGHTS (1985-87) 9-10 Amp EFI Control & Cruise Control Systems, Stoplights, Elec Controlled A/T System(1985-88) 10- 7.5 Amp Interior Light, Personal & Door Light(1985-88) Clock & Inspection Lights(1985-88) Luggage Compartment Lights (1986 2wd) 11- 7.5 Amp Discharge Warning Light & Emission Control System, Glow Plug Timer, EFI Main Relay(1984), Heater Main Relay(1984-86), Power Rear Window(1985-86 4WD) 12-20 Amp(Circuit Breaker) Power Door Locks (1986-88) 13- 20 Amp (Circuit Breaker) Power Windows, Rear Wiper & Washer (1987-88) 14-10 Amp A/C 15-20 Amp Heater Blower Motor 1- Blank 2- Blank 3-10 Amp Right Headlights, High Beam Indicator(1984-86) 4-10 Amp Left Headlights, High Beam Indicator (1984-86) 5-7.5 Amp Alternator & Discharge Warning, Emission Control System & Glow Plug Timer 6-10 Amp Hazard Flashers & Horns, Radio & Cassette Player (1984-86)
check this link-- In need of 1984 hilux fuse box diagram - Toyota Nation Forum : Toyota Car and Truck Forums
