22RE 4 speed.......whats the easiest and cleanest way to change the fuel filter on this thing? And where is it?
its under the intake manifold and above the starter. There is really no easy way to do it you probably will have to remove the starter to get to it.
Thats what I figured....any pointers on doing it. Someone told me to take the pressure of the fuel system???
Pull the passenger side wheel & remove or tie up the rubber splash guard. Should have better access & a clear line of sight!
To relieve pressure just crack the banjo bolt with a rag over the wrench so fuel doesnt spray you in the face...
if you try to sneak it out past the starter make sure you have the battery disconnected so you dont arc and set your self on fire too...
