fluid leak..name that part!
Discussion in 'Maintenance/Repair' started by crazedriver, Jul 1, 2015.
  1. crazedriver
    crazedriver Member
    Paradise Hills
    93 xtra cab
    Driving my truck today, as i pull in my driveway i notice consistent drops of fluid running from the street onto my driveway. I sourced the leakage to this line pictured...can someone let me know what exact line this is so i can order the part and replace it. i'm having a brainfart and cant think of the damn name and im not sure...pretty sure its PS fluid correct me if im wrong. thanks for any help
  2. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Yup PS pressure line.
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    I'd name it Fredrick but his friends and family can call him Fred. :lol:
    That is indeed the power steering pressure line.
  4. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    When you change the line out, use ATF to refill the system, NOT power steering fluid.
    I never understood why that line is 4 feet long and not a simple foot long, straight shot like it needs to be.
  5. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    If I may ask, why use ATF instead of PSF?
  6. White Trash
    Eastern WA
    Because all toyotas pre 95 spec dexron II or III not power steering fluid.
  7. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Ahh, thank you.
  8. crazedriver
    crazedriver Member
    Paradise Hills
    93 xtra cab
    thanks for the heads up. did not know that. this is the first toyota i've decided to keep my PS on instead of eliminating it.
    any particular ATF recommendations?
  9. White Trash
    Eastern WA
    I prefer whatever is on sale that isn't penzoil. :lol:
  10. Robert m
    Robert m Addict
    Apple Valley, Ca
    ^ x2
    Autozone brand ATF has worked fine for me for 2 years.
    I made the mistake of using power steering fluid when I did the conversion and the steering was always a little notchy. When I found out I should have used ATF, I did a flush and fill and the steering was 100x better and smoother.
