Feeler: Engine/Trans Mounts
Discussion in 'Vendor Marketplace' started by rajzswap, Nov 3, 2009.
  1. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    All of my work and fabrication is done with top-of-the-line equipment using Miller TIG welders to give you the best possible quality and strength in mounting the engines. Im wanting to have them sandblasted and powdercoated for mild steel or have them polished if you want stainless. Our kits are going to be top notch when finished and depending on the chassis and customer needs we can have them made with wither solid mounts ( recommended for racing/drag applications, and will be cheaper) or we can have them setup with aftermarket rubber mounts for the more comfortable ride. Mine personally in my trucks vibration is not noticable. but again this is a feeler to see what most customers recommend so we need your input on what you would prefer and why.
    Thanks,
    Rodney
