Exhaust
Discussion in 'Engine/Drivetrain' started by D_Ville1980Hilux, Nov 18, 2015.
  1. D_Ville1980Hilux
    D_Ville1980Hilux Newbie
    Duncanville Al.
    80 Pickup 2wd
    What type of muffler could I put on my 80 pickup. It has 21r motor
  2. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Whatever fits really....check YouTube for muffler sounds if you had a certain note in mind.
  3. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    I like the turbo mufflers on 4cyl. I think that's what they're categorized as. Straight through unrestricted perforated tube, surrounded by some batting to quiet the sound, they flow yet are fairly quiet at idle and not raspy. A glass pack is similar concept, but with minimal batting. Something like a flowmaster has chambers inside and you cannot see straight through it, to me they sound better behind a v8 and sound bad on small engines.
    I've got a 93, 22re truck that I upgraded most of my exhaust after CAT theft. It is pretty quiet but has some deeper tone and a little grunt when you're on it. It has stock header (1.5" ID?) going to maybe half length of the stock y-pipe (1.75"?), then I go up to 2" pipe and through a high flow CAT, then changes to 2.25"with a round mangaflow turbo muffler (6"x18" approximating here) and exits stock location.
    My new 75 pickup has a flowmaster and is carbed, but is significantly louder and I don't care for the sound, it's too ricey/flashy and stupid loud enough to set off car alarms. It's got a 20r with Webber 32/36, hedman header to 2.25" od pipe, through a 2.25" ID flowmaster oval muffler (unknown group, probably a 40), and out stock location. I plan to swap the flowmaster out. I was looking at summit catalog and found Jones Exhast, so I think I'm gonna use one of those since it's designed like a mangaflow, but at 1/2 the price :waytogo:
  4. D_Ville1980Hilux
    Duncanville Al.
    80 Pickup 2wd
    Ight thanks. I was thinking about a turbo muffler myself
  5. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    yup, turbo mufflers sound good. im running a 3in hooker maxflo. i think now they are called "aerochamber"
    like perkolator mentioned, its a straight through design with perforated chambers on either side of the main tube.(if that makes any sense)
    got a nice deep rumble at idle and screams at high rpms.
  6. Hilush
    Hilush Newbie
    Queensland Australia
    1979 RN41 2wd
    I just ran 2 2"x12" hotdogs on a 2" system on my 79 with 18rc but now I have the 18RG with extractors I run a turbo muffler and 1 2"x12" hotdog on a 2" system with a dump pipe in front of the diff.
  7. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    Hot Dogs??
  8. Litneon
    Cocoa, FL
    94 xtra cab
    Perforated core resonators...
    And extractors are headers.
  9. Perkolator
    Placer County
    1975 Hilux
    so that's like a short glasspack?
  10. Litneon
    Cocoa, FL
    94 xtra cab
    12" is rather short, but mine's only 18" long.
    Interesting side note... Perforated core resonators actually flow exhaust gasses better than straight pipe.
