engine turns off when battery cables are disconnected
Discussion in 'Maintenance/Repair' started by toyocrazy, Nov 19, 2010.
  1. toyocrazy
    toyocrazy Newbie
    1991 truck turns off when battery cables are disconnected. took off alternator and took it to get it checked at an autoparts and told me it is working fine, i installed it back and still have the problem any info would be apreciated thanks!!!!
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    im confused... are you are running the engine and taking the battery off.. its normal for it to stall this truck needs a battery in it.
    or are you jump starting it with another battery and when you take the other battery off the truck stalls? if thats happening the battery in the truck is super dead or even shorted and needs a new battery.
  3. toyocrazy
    toyocrazy Newbie
    i just bought the truck and after couple of days of using it battery when dead. so i bought a new battery> i left the engine running while swapping the batteries and engine turned off. so i was told that the problem might be the alternator but it has already been checked and still has the same problem
  4. dillinja666
    ya.. just put the other battery in without the truck running.. its going to stall EVERYTIME if you pull the cables off with it running.
    If the battery keeps going dead with the new battery you might have a "parasidic draw" which means something on the truck is staying on killing your battery. could be as simple as a glovebox light or interior light, could be the alternator or main ECU ( if its an RE ) thats an easy test but i dont feel l ike typing it all right now if thats not the problem.
  5. garagedoorman
    garagedoorman Addict
    north georgia
    that means you need an alternator. Your truck is running off of the battery and the alternator isn't recharging the battery
    Muttley81 likes this.
  6. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Truck must be crap. Sell it to me.
    If not re read what dillin wrote. The truck not going run without one battery. Try swap the batteries and see if it runs. If not ill give you $500 for it. Let me know.
  7. toyocrazy
    toyocrazy Newbie
    couple of the days of use and battery goes low and wont start
  8. oahu grown
    Hawaii
    92 Extra Cab
    And why would you want to change batteries with the truck running? Seriously? What The hell
    Dude you should edit your first post and post all the information you can possible give the first time. Would make things easier.
  9. dillinja666
    ya, something is staying on.. do you have access to a volt meter with an amp setting on it?
  10. toyocrazy
    toyocrazy Newbie
    but the autoparts guy said the altenator was throwing about 13 volts when he checked it
  11. dillinja666
    im not doubting what the parts guy said..i asked if you have a meter. im gonna teach ya how to track down your problem.
  12. garagedoorman
    north georgia
    A vehicle will run without a battery hooked up. It needs both an alternator and a battery to continue running. In his case the alternator isn't recharging his battery so the truck ran till it killed the battery.
  13. dillinja666
    i think you are confused. he removed the battery while the truck was running.
    well i might be wrong.. the guy at work says it will run for a lil bit with the battery out. so either the parts guy is wrong which ive seen or he has a draw....either way someone needs to look at the truck for him .
  14. oahu grown
    Hawaii
    92 Extra Cab
    Yeah he was trying to swap batteries with the truck running.
  15. toyocrazy
    toyocrazy Newbie
    thanks guys for the info!!
  16. garagedoorman
    north georgia
    correct and then it died which tells me the alt isn't chargin. then I read its at 13 volts. should be at 14 volts
  17. toyocrazy
    toyocrazy Newbie
    will buy a volt meter and let you know when i have it, thanks a lot for the help!!!
  18. dillinja666
    13-14 is usually healthy enough, but im starting to suspect his alt isnt putting out any amps and barely is putting out enough voltage. bet if he ran it with his headlights n stuff on it would dip down into the 12's
  19. dillinja666
    no worries.
  20. oahu grown
    Hawaii
    92 Extra Cab
    I think he has a draw coming from somewhere. Or maybe a bad ground.
