Engine Help
Discussion in 'Maintenance/Repair' started by Dioxine, Dec 27, 2008.
  1. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    make sure the wires are on the distributor cap correctly, by this i mean the order.. i dont have my manuals on me to look it up sorry :(
  2. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Check for a intake manifold leak. Air that is leaking in after the MAF sensor can cause surging like that. To check for a leak take a can of brake clean and with your engine running spray around the manifold gaskets and listen to the engine. If it smooths out or revs up higher you got a leak. Another thing to check would be your IAC. Idle Air Control. They can cause Surging at idle. However im not sure if Toyota uses them on the earlier Trucks.
  3. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
  4. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    k, kool. i thought that was the firing order, just didnt want to post with out double checkin..thanks ibeseen!
  5. Dioxine
    Dioxine Newbie
    Belle Plaine KS
    90 Toyota P/U
    Hmm I havent checked the for leaks but i checked the air vane and it was working properly and i have the wires on right. I replaced the spark plugs and this made a difference but the surging can still be felt every now and then. The plugs i took out looked new on the outside but were orange and black on the tips. Im assuming this meant the motor was running lean assuming that the injectors had been clogging. If someone could also find me a vaccum diagram a 90 22re that would be helpfull to.
  6. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Are the diagrams not on a sticker somewhere under the hood??
  7. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    replace the wires cap and rotor !
    IDK why but whenever I try to replace my cap and rotor from advance auto. the rotor they give me NEVER WORKS! so Im running the stock rotor but new everything else
  8. yellow87toy
    yellow87toy Newbie
    Statesville, NC
    1987 Toyota 22r carb
    cat problems... after 5 min's of driving the cat is hot enough to cause the motor to bog down
