Electrical gurus, lighting has me stumped...
Discussion in 'Interior/Electronics' started by Bronchogg, Apr 19, 2016.
  1. Bronchogg
    Bronchogg Member
    Salt Lake
    71 Hilux
    I've got a weird wiring issue. Maybe someone has a suggestion/answer.
    Specs:
    1971 Toyota Hilux
    8rc with 4 speed
    My fender mount turn signals aren't working properly.
    I have replaced the Nippondenso flasher unit with a 2 prong electronic flasher.
    I have replaced both bulbs and cleaned both sockets.
    Throughout all tests, rear blinkers and taillights work properly.
    Symptoms...
    Ignition on and not running. (Same symptoms while running)
    - Both blinkers work. However, the passenger side is bright and drivers side is dim.
    Ignition on, headlights on and not running. (Same symptoms while running)
    - Drivers side front stays brightly lit (using the larger flasher filament instead of the standard filament) with no flashing. Dash light does not flash.
    - Passenger flashes as it should - front, rear and dash.
    Ignition on, hazards on.
    - Drivers side now flashes but only with the smaller, less bright filament.
    - Passenger side works as it should.
    Engine on, hazards on.
    - nothing
    - anywhere
  2. Bronchogg
    Bronchogg Member
    Salt Lake
    71 Hilux
    After reading the Haynes manual (the Chilton manual is virtually ZERO help when it comes to the 1st gen.), I think the best thing to check would be the turn signal relay. I'm just not sure why the bright/dim would change sides.
    Any other suggestions would be greatly appreciated. Thanks!
  3. jetas
    Check the relay, and headlight switch. Pretty sure all the light wiring goes thru that switch.
    Just check the wiring
    Bronchogg likes this.
  4. Bronchogg
    Bronchogg Member
    Salt Lake
    71 Hilux
    I'll probably just start the process of elimination. I know the flasher is working although I don't like it - not a "loud" unit so it doesn't make an audible clicking.
    Either way, I'll be tracking down new headlight/hazard switches and move on from there.
  5. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    You're probably going to end up running new wiring. Based on the age of the vehicle, building a complete new harness for the vehicle wouldn't be a bad idea.
  6. jetas
    Aftermarket harness. I used one on mine. Took me a while but well worth it. Now i know shits all new.
  7. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Something that old I'd definitely go with a new aftermarket harness.. I've thought about doing a Painless harness in my other truck, doesn't look difficult just time consuming.
  8. jetas
    From what i read when i was doing mine, practically all the aftermarket harnesses are identical in wire color and all that. Price point changes with the brand. Painless is overpriced IMHO. I went with EZ Wiring but theres others out there that are more complete for jus a bit more $. And still below painless prices.
    first80toyota and Bronchogg like this.
  9. first80toyota
    Pacific Northwest
    '77 Hilux
    I only mention Painless since most everyone knows of them..
    When I was looking at them for my truck i noticed most aftermarket harness kits use the GM color codes.
  10. Bronchogg
    Bronchogg Member
    Salt Lake
    71 Hilux
  11. Yotaboy
    Yotaboy Member
    hope this helps
    nnywg and 90DailyDriven like this.
