I've got my truck dropped as low as I want and instead of going with 17s I want to go with some 0 or -10 offset 15s with some serious negative camber up front. Does anyone know if this is doable or how difficult it would be to do? Any pics of a similar setup would be great! Thanks
The offset will work as far a camber like hellaflush or wrongfitment crew that much camber is unsafe hard on parts .I think lowering the front about 3 inches with that wheel setup will get u what you want
if you dont really care about driveability, tire wear, or safety, then allot of camber is possible. just add shims up front till you achieve your look. you may need to find longer arm shaft bolts. rJay just took out a bunch of camber off his truck since it had camber issues before we did a slam up front. he is running a 55 series tire so it wasnt too bad. he's still got a little camber up front...... enough to keep us from needing to pull the fenders over.
i set my truck up with -1 dg of camber in the front. give me the look i want and help on the track. when i put thw supra irs in, i run -1 in the back.
Thanks guys. Before I had the truck I had an ae86 and wanted to try and replicate that extreme negative camber up front. Haha just for something different.
I also felt that -1* of camber on the trucks help a lot with handling. I did autocross with 0* camber and still got 1st place in my class, but i felt that a hair of camber could've helped me a lot
