I have a complete rolling chassis from a 1985 Toyota SR5 Extended Cab for sale. Comes with the engine, trans, rearend, harness, steering column, seats and interior parts. The wheels are OG Rikens with good tires. The engine will need a headgasket as it just started giving a little white puff from the exhaust. There are many new parts that have been installed in the last 7000 miles. If I break it down the engine will come with the complete harness, airbox and tube. The transmissin is a 5 Speed and in good working order. Newish parts are Fan clutch and fan Cam chain cover and heavy duty chain kit with steel guides Oil and waterpump EGR valve Fuel Pressure regulator Crank Dampner Rad Hoses Shocks Rear brake cylinders Rad was flushed and is in good shape Clutch master and slave cylinders Gas tank Fuel pump and sender I have a new Driveshaft mid bearing The interior is brown and there are a few good parts that are not cracked from heat/age The steering column is in good shape. It is a low mileage truck so the tilt is tight and ignition works well, has keys the seats will need new foam and covers. Door panels and column cover are gone. The chassis has a receiver type hitch. The truck was not crashed. It would be a good start for someone wanting to do a EFI conversion or doing a straight axle swap or lowering project. $600.00 takes it all. I will separate it if it does not sell as a whole. I will have interior parts pictures when Its light out
