does this serve a purpose other than emmisions? bcuz i wanna bypass and plug all that and remove it so i have a clean engine look. thanxs.
haha. nice term. and yes, it just takes fumes that leave the gas tank and trys to clean them for the air a little. sure is a big ugly thing though. theres quite a bit of mess that can be cleaned up.
heres a few quick ones of how clean these bays can get fairly easily. the rust is only because i hammered my inners so much for clearance that all the paint cracked off. lol. i also shaved all the extra bolt holes/mounts on the valve cover. and took out my a/c stuff. i have a freshly rebuilt head and intake as well, and swapped to the smaller 81 style master/booster.
I love my AC you carb guys make engine bay cleaning look so easy.... I need to do my battery intake swap....
your truck has an electric fuel pump?? is that stock or did you install tht yourself?ive been thinking about putting one in and canceling my mechanical one.
im looking to get an electrical fuel pump too clean up the bay that much more...i run ac on my 22r and my motor is pretty clean because i shaved alot of my smog stuff and alot of unnecessary ground wires that i hid n grounded else where...good luck bro...
Here is a Pic of mine once I removed all that cluttered canisters. I love how open and clean it makes it look once you remove all that crap.
yes, along with both vsv's, the bsv, ac idle up, ps idle up, egr valve, egr modulator, and related vacuum lines. On my 4runner 22re I have a vacuum line from the charcoal canister to the throttle body, the brake booster, and the intake manifold to the fpr. That's it.....
yeah i spent alot of time on that valve cover. shaved off extra mounts and even that raised front area the sticker sits on. i will sell it when i do a new one in powder coat with a new color. and yes stock electric pump in tank. i could sell the brackets, pump, lines and engine room parts most the dash stuff youd have to figure since its part of my heater core and never took it all out. i removed enine room stuff to clean it up since it needed to be recharged
yah pm me your details! yesss ac haahha, and yup not available, i goin try do something this weekend and post pics and stuff, lol and one day after school ill just rip all that **** out.
uhhh....ok...so you still have the charcoal canister??? I'm gonna run ac, so should I keep the ac idle up? you got any pics?
im currrently redoing all my wires..heres a pic...itll look cleaner and its really easy just time consuming cuz i hate electrical work -__-
ill do up a valve cover like that for you if you send me a core. for anybody. its not that tough. i like working with aluminum
