I changed my serpintine drive belt that goes on the crankshaft, fan, and alternator pulley but ones I put everything back together it wont start? PS I forgot to disconnect the battery and the positive on the alternator touch ground could this be my problem?
I wants to start but I checked for spark and its not getting any spark I used a test light to check for spark and didnt get anything maybe I am doing it wrong?
Ok ill check them out right now the only fuse I really checked was the engine fuse because I have an electric fuel pump
Ill check tomorrow morning and what if it doesnt spin? I heard if it doesnt spin then the timing belt/chain is broken?
Yeah you have to remove the valve cover to see. Most likely the chain is broken. Happened to me took me about a hour and a half to do the job not that hard of a job.
Ive looked of on youtube how an engine sounds with a broken chain and my truck doesnt sound like the chain is broken because it wants to turn over but I guess its not getting spark but I dont want to replace the igniter or coil if I am not 100% sure they dont work and thanx guys for replying I will check it out in the morning.
check the battery, check all grounds. if you moved ANY wire, check it. if you moved a bracket that something grounds to, check it. If you touched something, check it. if all else fails, post some video of you trying to start it and we'll check it.
I checked today if my chain wasn't broken and it wasn't because I took the distributor cap off and when I tried turning it over it spins. And how do I post videos up on here?
