Small ports and valves have better velocity, so they retain a bit of the bottom end that a race prepped 22r head would sacrifice for top end power. But other than needing a cam, I can't complain about top end power on mine. For a bunch of basically stock parts, and some top end work...it moves great.
Sorry I have been busy with school and haven't been keeping up on the forum. I am the same guy who sold you the parts in Newcastle. My dad was the original owner of my truck and the only thing he did was install a radio. Your first thought when you saw the block sitting there you thought it was a laser block. How can I check? It does have domed pistons. How hard would it be to put the double chain gear into the single chain 22r? I have a 20r crack with the double sprocket on it. Anyone happen to have a spare 20r head around I could get for cheap? I only have the head 20r on my daily driver. Would it work somehow to use the stock 22r head and increase compression? I think I heard the chamber shape is what changes between heads but I am just wondering.
22 head on a 20 block will have ultra low compression. Guys at engine builder told me about 7.5ish. So without boost, it would lose power. 81/82 22s had a double chain. 83/84 had a single, but were still the shorter engine block. You can use 20r cover plate and a timing chain kit for a 75-82 20/22r. Water and oil pumps are the same, as is the balancer.
We musta been having the same thoughts at the same time, FWIW, late model, laser block engines, late 84 to early 85 and up had a short deck and short head, early engines used a taller block and taller head.
Wouldnt it be easier for you at this point to bore the crud out of a 20R and use 22R early pistons? Ive heard it takes quite a bit of milling several parts to a late 22R engine to build a hybrid. Would'nt be worth it IMO. :hyjack: What kind of 22RE head is a single chain 84 celica, tall or short? Same or different than a 81/82 other than the chain sprocket? Just wondering...
my bad. laser blocks are taller. to run a 20r head on them you mill the head. i have an 81 block with a 78 head in my truck now. runs great. and you can ultra bore a 20 block but your machine shop will hate you. its a 3.5mm difference in bore stock vs stock. thats about .140" overbored. but if anyone wants to, i have stock 81 pistons
either way, the 20r head needs a decking to match up to the laser. see everyone, this is why i don't like the laser motors.
