brake upgrade
Discussion in 'Suspension/Chassis' started by nathan04low, Jul 13, 2008.
  1. nathan04low
    nathan04low Newbie
    Brisbane, Australia
    97 toyota hilux (same as the US pickup)
    hey guys, i really want to run some big front brakes, my aim would be to use wilwood calipers and rotors, does anyone here know of someone that could help me out?
    i pretty much need part numbers and maybe someone who has an adapter that will work or a CAD drawing of an adapter that i can get laser cut here
    thanks
    Nathan
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    This mod is posted on here,use the search. I recently got the brackets to use the Toyota 4x4 calipers,& have the hats & rotors sitting on shelf ,also got a 1" master cylinder,hope to start putting together in the next week or two.
    The Wilwood rotors # is 160-7106/#160-7105;Wilwood hats #170-1827;if you use the wilwood calipers( I plan too which once the person on this site gets brackets made to use them) ,#120-6815/#120-6816
    He still had some of the brackets for the Toyota calipers,got my calipers off-bay,around $140 shipped. Found the best prices on the rotors & hats @ carshopinc.com
    Will also needed 2 bolt kits,#230-0150
    Hope this is of some help:cool:
  3. phatmitzu
    phatmitzu Veteran
    SoCal 626
    93 Standard Cab 5spd
    TA,
    Did you ever get the BBK done?
    I just got myself a set of 4x4 calipers and got the brackest from the forum member here. Gonna go shop for the rotors now...
  4. DTKStout
    DTKStout Member
    Oroville CA
    Too many to list.
    This guy makes a complete front brake kit for toyotas. It is similar to the willwood setup. www. phattys. ca Is the link to his website.
  5. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    It's a nice set up, expensive, & read somewhere he wasn't making them any more. Revolation brake has a Wilwood front kit & can make a rear,again a lot of money.
    Just started the front upgrade,& running into a problem with the bracket holes??:cool:
  6. phatmitzu
    phatmitzu Veteran
    SoCal 626
    Whats the problem?
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    The bracket holes for the caliper are too close to the spindle,need to grind into the caliper about 1/4" @ both ends !
    Any body else run into this problem??
  8. Litneon
    Cocoa, FL
    94 xtra cab
    Yes, sorry for the inconvenience, but this was always the case from up front. The caliper has to be modified slightly.
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I awesome you just grind the corners until you have the correct fit?? :cool:
  10. Litneon
    Cocoa, FL
    94 xtra cab
    Yes, you shouldn't have to take much off, and you can remove material from the spindle too if you don't want to take all the material off of the caliper.
  11. trap
    trap Addict
    orange county ca
    92 pickup
    I had to grind for the revolution kit too, instructions are clear showing where exactly to grind. I am putting in drop spindles at the same time as the brakes and so it was not a big deal . I don't have the kit on yet but I promise a thread with pics when they go on.
    I know for a fact if you email, or call Philip at revolution you can get a kit with 1 piece rotors for significantly less then the price listed on their website for a kit with 2 piece rotors. the kit uses wilwood superlite 4 piston calipers and 13 inch rotors.
    Philip told me he has a 89 yota pickup shop truck with his big brakes and a 3rz that he plans on swapping into it, I sleep better at night knowing I gave my hard earned cash to someone that actually knows brakes, and drives the same truck as me
  12. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    how much does this brake kit cost roughly ?
  13. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Yeah thought of that after grinding the first side. There is 30mm from the outer edge to the hole,removed 5mm!
    Side one is finished:cool:
  14. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Changed out the master to a 1" one & @ the same time the booster to a double diagram.
  15. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    While in the area I made & installed a polished plate under the clutch master ,where there was damage to the Line-x
  16. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Next up was the bracket
  17. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Then the problem of fit,easy fix
  18. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  19. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Then the longer wheel studs
  20. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Once I could get all in place found I had the trim the pads .as made contact with the hat
