Between Show Repair
Discussion in 'Maintenance/Repair' started by TRUCK ACTION, Apr 13, 2016.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    So I've had this squealing drive belt for a while ,comes & goes! Been using belt dressing to quite it down,finally dressing the problem!
    I had changed to a GM 12 SI alternator a few years ago & had to modify the brackets.
    I suspect the alternator pulley not to be in line with the crack pulley,so I moved it rearward a little & lengthen the upper support bracket so can put more tension on it!
    Should finish this up today,& will see if problem gone!!!
    Mikerocosms likes this.
  2. jetas
    Hopefully it cures your issue. Squealing belts are fckin annoying
    twizted1 likes this.
  3. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    I second that jetas!
