Best Wheel Polish??
Discussion in 'Wheels/Tires' started by CREETIN247, May 12, 2014.
  1. CREETIN247
    CREETIN247 Enthusiast
    Columbus, OH
    86 Std
    So I picked up some Crown Vic mesh wheels this weekend and they're in pretty good shape for the most part but the clear is comin off on a few spots so I'm gonna polish them! What's the best polish??
    Just a few I've seen on some other fourms
    Meguiars NXT All Metal Polysh
    Mothers
    Autosol
    And whatever else someone can recommend!!
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    I have a personal preference to Mother's aluminum polish. I used the actual paste with a high speed drill.... here are some before and after shots.
    Trankeylo likes this.
  3. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Yeah Mother's is the shiznit. I used to use that on my aluminum wheels all the time. Great stuff.:waytogo:
  4. Kev55
    Kev55 Enthusiast
    florida
    There's one I used before that came in the form of a soaked cloth rope you cut in segments and rub the wheels down..worked very well... it was a little black container. forgot the name though :-/
  5. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    I think I know what your talking about. I've used that same stuff on chrome to remove surface rust while polishing to a nice shine.
  6. SD YOTA
    Never dull?
  7. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Yeah, Never Dull and the stuff in the black can I can't seam to remember what it's called. Aluminum foil and water work well on chrome too for surface rust.
  8. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    I like Flitz.
    In the end though, I think it is just a matter of elbow grease. They will all eventually get aluminum to a mirror-polish.
  9. raylcc
    raylcc Addict
    Denver, CO
    The tears of young virgins! I've found that the red tub of rubbing compound seems to work well. especially if its a wheel that hasn't been polished before or has a lot of dulling. a good polisher helps as well to help with the "elbow grease" part of it.
  10. CREETIN247
    Columbus, OH
    86 Std
    Anyone a fan of Meguiars??
  11. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    I like the Meguiars NXT all metal polish, I've used it on aluminum and stainless, it works well. I also like the Mothers stuff. It really comes down to how much effort you want to put out, I use the red power ball polishing ball when I can, otherwise my arms are usually wore out before I'm done.
  12. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Awwww the joys of detailing.
  13. Litneon
    Cocoa, FL
    94 xtra cab
    It's really more about how much work you are willing to put in than the actual product. I've used a lot of different products over the years. They all work well, if you are willing to do what's required to make them work.
    Which now that I reread this, seems kinda obvious. I'll go away now....:eek:
  14. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Well, then how about techniques? Tools you guys favor, the process...
    I'm looking to do the lip of my cv mesh wheels...someday, lol.
  15. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Let's see..... coarse, medium, fine steel wool. Then 1000 grit to 1500 or 2000 grit sand paper. Then the aluminum and mag paste polish. With some good olé elbow grease and a microfiber towel.:waytogo:
  16. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Sounds like fun! Haha
  17. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    O man talk about good times.:waytogo:
  18. raylcc
    raylcc Addict
    Denver, CO
    I've used the above mentioned rubbing compound and a good polisher with a buffing pad to do the heavy work. It beats wearing your fingers to nubs. The sand paper would probably be faster but having a polisher do the work for you is easier on the arms. I knew a guy, before the Mothers polishing ball thing came out that swore by old t-shirts or sweatshirts, zip-tied to a small nerf football, which was attached to a drill. He ran a long carraige bolt through the end of the ball until it was recessed into the foam and tightened the drills chuck around the other (threaded part) of the bolt. he then put the t-shirts/material around the football and zip-tied it tight near the chuck.
  19. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Interesting:thinking:
  20. CREETIN247
    Columbus, OH
    86 Std
    Got 2 wheels sanded to be polished over the weekend. The one thing I hate doing the most in all my projects that I do is wet sanding!! :brickknock:
