Best brand or source of head gasket for 22re
Discussion in 'Frequently Asked Questions' started by Boss66, Nov 21, 2014.
  1. Boss66
    Boss66 Newbie
    Anybody use a 22re head gasket from Toyhead?
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Use OEM.
  3. aseq
    aseq Member
    CA Bay Area
    87 2wd, Carb, Longbed xtra cab
    I would say use oem if you can. However I swapped a head/gasket/timing chain etc. about 3 years ago and I used a felpro gasket set bought at the local autozone and it's been working great. I think I have put about 60k miles into it (20k yearly commute). It's more important to make sure the mating surfaces are very clean and flat, sand the cast iron surface of the block, make sure no traces of old gasket or rust is left. Torque everything correctly and in the right sequence, re-torque after 500-1000 miles. I used about 75 ft lbs.
  4. jetas
  5. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    OEM.
    Prep is key!!
