Ball joint/ tie rod brands recommendation
Discussion in 'Suspension/Chassis' started by Juicyy, Mar 31, 2017.
  1. Juicyy
    Juicyy Member
    Norcal
    1993 single cab 22re 5sp rwd
    Hey everyone.
    It's time for me to consider replacing my ball joints and tie rods to tighten up my steering. I'm on a 1993 2wd with 137K under the bonnet, and I think everything is original. The steering wheel has a good amount of play, I can drive down the freeway and jiggle the wheel and you won't feel a thing.
    Has anybody had great success with no name aftermarket brands like AM Autoparts or A1 Autoparts? Do people prefer to use name brands like Moog on your replacement parts, or do you go as high up in quality as to buy OEM Toyota parts?
  2. jetas
    I bought all moog for mine. About 200 for 4 ball joints, 4 tie rod ends and new tie rod adjusting sleeves
    yota4life and twizted1 like this.
  3. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Make sure that the lower ball joints have castle nuts. I bought a set of moog ball joints for my last truck, and only the top had castle nuts, the lowers had just nylon lock nuts.
  4. BatryOpratedBoy
    BatryOpratedBoy Enthusiast
    Fresno. =(
    Brave Little Toaster (Diana) and Salsa Verde (Traction Control)
    Also if applicable make sure to check the lash on your steering box. Basically a 12mm box wrench and a flat-head. Don't turn it in too much or it will bind when steering... I basically adjusted it till (when twisting the steering shaft by hand) it moved a reasonable amount but didn't bind through the range of steering.
  5. Juicyy
    Juicyy Member
    Norcal
    Thanks everyone,
    I'll try adjusting the lash first, if it still has excessive free play, I'll look into dropping two Benjamins on some parts.
  6. fred heath
    fred heath Addict
    Raleigh, NC
    Check for play in the pitman arm.
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Yes on Moog, been around a long time!
  8. Juicyy
    Juicyy Member
    Norcal
    thanks everyone. I checked the connections; the ball joints, tie ends, pitman arm and idler are all tight, but i do have excessive play in the lash. i'll get to adjusting that first, feel how it rides, and go from there. great info all around!
    TRUCK ACTION likes this.
  9. neonjay
    neonjay Member
    Another vote for Moog. Have them and have no problems so far. Their warranty is great also.
  10. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Late to the party but I vote for parts made by Sankei "555" -- name is cast into the metal. Typically reboxed into other brands like Moog and Beck Arnley, etc.
  11. unclejesse
    unclejesse Newbie
    I agree, I've found 555 in both moog and beck arnley before. also found nippendenso electrical items in beck arnley before. Also, the moog that i have bought recently that wasn't 555, seemed to be not very good quality.
