Another thing on my winter to do list
Discussion in '1984-1988 Pickup Discussion' started by TRUCK ACTION, Jan 14, 2016.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    So one of the things on my winter work list was to change out the nylon bushings on the trans tower that the sifter shaft sets into & on the shaft end. Got these from LC a while ago,any way it fit seems that there are three different sizes, my trans is a W55, so now have to wait to get the red one LC is sending.
    If any one is replacing this item measure the hole OD!!
  2. jetas
    The new shifter bushing makes a hell of a change if the original one is busted
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Yeah,the bushings I removed I changed out in 2006 when the new LC Pro Street engine went in ,the shiftier is there short throw unit. I've had a nose in 5th gear when you ease up on the throttle for a long time & replaced all the bearings in the trans last winter,nose was less but still there. I noticed that when I pushed forward on the shift shaft at speed the nose went away so hoping the bushings were just badly worn, the large one was very soft!
