Anyone have any links to air for these trucks.? I've done a suicide doors wishbone 5link on a Sonoma I used to own but have been away from any forums for a few yrs. Thanks Macon
There's no bolt on kits for these trucks like s10s an full-size trucks. Everything is basically a universal cut to fit
Yes the above is what you should price out from all the suppliers you can find,comprise a list with part numbers & prices & go from there! The same will go for you fittings & valves,draw out what lay out you want & change on paper as you want ,make a list & start collecting parts ,in less you can get all @ once!! My advice on air tanks is go with stainless,you can paint or power coat if not wanted polished,but the inside contaminates will be only water, & the use of water traps in the set up will solve that problem!
i have a 89 extra cab looking to bag it also i have a company saying the bags and bracket are 400 is that good i really dont want a super notch just a mild c notch
Bags and brackets arent all youre going to need. Link set up for the rear plus other chassis work. Its not a simple task. And sorry but a mild c-notch is good for static trucks not bagged. Do more research
