94 toyota 4x4, 22re brake line issue + need pdf FSM
Discussion in '1989-1995 Pickup Discussion' started by Wolf714, Apr 24, 2016.
  1. Wolf714
    Wolf714 Newbie
    My 94 truck just popped a brake line coupler leak. Inside right front wheelwell, bolted to the frame, is a set of two couplers; one looks like a backwards L, the other, an upside down T
    I'm mechanically inclined but not a mechanic.. I ordered the part which has these two couplers attached, and I wonder if changing it out is something I can do, without damage or problem
    The L coupler is leaking badly, the T is fine, but because they are both attached to the one bracket bolted to the frame, I gotta remove the entire part
    Looks easy -- just don't wanna eff it up ;)
    Anybody been there, seen this ?
    The couplers/ bracket cost $78 OEM-- from dealer - is that reasonable or can I better that ?
    Thanks and happy trails in best trucks on the planet !
  2. Frinzo
    Frinzo Toyotaholic
    Great Lakes, IL
    '86 Std Cab
    If its a brake line fitting, shouldnt be hard, but u will need to bleed all the brakes. Just have enough brake fluid on hand and just double check that u got all the air bubbles out.
