84-95 2wd BIG BRAKE 4piston caliper adapters
Discussion in 'Suspension/Chassis' started by MTB68TOY, May 6, 2008.
  1. Chip Morton
    Chip Morton Member
    San Diego, CA
    I'd rather have the stands for the Toyota calipers. The Wilwoods are expensive!
    So I'm down for a set. I'll PM you a note in a minute.
    Chip
  2. Litneon
    Cocoa, FL
    94 xtra cab
    The cost per caliper is about the same between the OEM's and the Dynalites, unless of course you have cores.
  3. laynrocker84
    laynrocker84 Member
    marshall TX
    87 reg cab 2wd
    are there any of these available now?
    Thanks
    Trey
  4. planemos
    planemos Toyotaholic
    British Columbia
    I just did it all myself and got a local machine shop to help me. It's not very hard for a machine shop to do. I made a simple design. Just a thick piece of steel with 4 holes and an offset. And a mirror image of it equaling 2 pieces of steel.:D
  5. Chip Morton
    Chip Morton Member
    San Diego, CA
    How much did they charge?
    I worry about my measurements being accurate. :duh:
  6. garagedoorman
    garagedoorman Addict
    north georgia
    Liteneon knows this guy (MTB68TOY) well, they've work on projects together. Also his email is in sig, send a message.
  7. planemos
    British Columbia
    Only a bit. I think about $50. I had just given the dudes a mocked up version (welded nuts to a chunk of steel) and they made up the nice version. It ended up being off by a tiny tiny bit. I had noticed when I got the brackets home. So I took a drill bit and reshaped one of the holes a lil bit. It didn't bother me to do that. It still worked great for me.
  8. Chip Morton
    Chip Morton Member
    San Diego, CA
    Damn, really? I'm going to have to check into that.
  9. Litneon
    Cocoa, FL
    94 xtra cab
    I think that I have one set of the original stands. I will check. If you check out my first write up on the mod, you can see how I built my prototypes.
  10. Litneon
    Cocoa, FL
    94 xtra cab
    Darn, I just checked and they aren't where they used to be. If memory serves me correct now, I think I may have given them to a friend of mine, sorry.:(
  11. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    judging by a post in the other thread on these stands it looks like they were made by CNC Machine Shop | Custom Waterjet, Plasma, Laser Cutting | eMachineShop.com
    Hi Michael,
    The order status information you requested:
    Order # | Status |Estimated date of receipt
    168746 Shipped 7/24/2007
    Function of part: adapt a larger brake caliper
    File name: CSfinalTHIN100mm.ems
    Machine: 991. Plasma Cut
    Shiped on: 7/23/2007
    Actual shipper: UPS
    Shipment reference: 086892-168746
    Use following URL to find out delivery status*:
    UPS -- Document Not Found
    *Copy URL and paste it into your browser address line and hit ENTER.
    Thank you for your inquiry.
    ==== eMachineShop ====
    i'm thinking if you contacted them with the work order/invoice # (168746) they could pull up what it was and make more. just a thought lol
  12. hilux8993
    hilux8993 Newbie
    Ft. Lauderdale, Fl,
    93 Std cab pickup
    That sounds like a good idea....
    YOu think that would work..??
    I would order some....
  13. Litneon
    Cocoa, FL
    94 xtra cab
    I would just check with Mike first. This is technically his intellectual property, and while he will probably agree, ask.
    Just to keep everything on the up and up....
  14. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Lol!!
    Well well... I guess I will finally get an order of these made
    Since no one will make a deposit or get a group buy together I'll cough up the $450+ this cost to get 10 pairs made...
    Oh and just for reference... Emachineshop wants $200+ each if you order just two... Thus I make an order for 20 which brings the price to around $50 a pair... (I sell them for $75 shipped)
    I just emailed emachineshop about a reorder, they got back to me with a phone number, I'll give them a call tomorrow... I has taken about 3 months to get the last two orders
  15. Chip Morton
    Chip Morton Member
    San Diego, CA
    Keep us posted.
    I'd still like to investigate an option using an OEM hat type disk off of a 5-lug Celica as that might be cheaper. But that cost savings might not be worth it if I had to fabricate brackets. A bolt on is always so nice.
    This is the Celica rotor I was thinking of looking at. This is from the NAPA web catalog.
    NB*4886041
    Year: 1986-1992
    # of Bolt Holes*:*5
    Bolt Circle Diameter*:*4.5"
    Brake Rotor Diameter*:*11.88"
    Brake Rotor Discard Thickness*:*.83"
    Brake Rotor Thickness New*:*.87"
    Brake Rotor Type*:*Disc Brake Rotor
    Center Hole Diameter*:*2.37"
    Height*:*2.11"
    Maximum Lateral Runout*:*.004"
    Mounting Type*:*Type K - Rotor Only. Wheel Studs Are Pressed Into The Hub Only. The Rotor Is A Loose Fit On The Hub & Is Retained By Either Machine Screws Or The Wheel Nuts. See Diagram For More Information.
    Vented / Solid*:*Vented
  16. Chip Morton
    Chip Morton Member
    San Diego, CA
    Hey MTB68TOY, I'll pre-pay for a pair in full in order to help out. I'll send you a PM.
  17. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    NeW OrDER!!
    Well, the good news is... I submitted a new order! Bad news is that unfortunately the economy has changed as with the material pricing list for emachineshop... Bottom line I'll need $100 shipped a pair this time...
    Should take about 4-8 weeks
    I made a paypal button for you guys, follow the link below.... Limited number available...
    MTB
    http://www.wix.com/mtb687/4wdyotastands
  18. Chip Morton
    Chip Morton Member
    San Diego, CA
    OK, I'm in. Payment sent. Boom!
  19. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Stands have come in!
  20. Chip Morton
    Chip Morton Member
    San Diego, CA
    Got my stands!!!
    Thanks, Mike!! They look great. Now I just gotta hijack some time in my dad's garage.
