8.0" rearend
Discussion in 'Engine/Drivetrain' started by Blacklightnin55, May 29, 2017.
  1. Blacklightnin55
    Blacklightnin55 Member
    Louisiana
    1990 Ext-cab
    Will the 3rd member from a V6 rearend which has a 8.0" ring and pinion gear fit into a 4cyl rearend which has a 7.5" ring and pinion gear. Trying to get to a LSD rearend Supra spool. Im wondering if I must change out complete rearend or just the 3rd member.
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Whole axle, the 3rd members are not interchangeable.
  3. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    The 7.5 and 8" parts are not interchangeable. Like WhiteTrash said, you'd have to swap the entire axle assembly in order to use the 8".....also, make sure it's from a v6 2wd or you'll have an issue with 5 lug vs 6 lug :) (4wd have 6-lug)
  4. White Trash
    Eastern WA
    According to the pic he posted in his other thread it is a 2wd axle. The e brake cables are totally different between 2wd and 4wd. The picture is of a 2wd.
  5. Blacklightnin55
    Louisiana
    1990 Ext-cab
    Thanks for all the info. Going to pull 3rd member from 8" rearend and send it along with supra spool to get rebuilt and rework for LSD. Just waiting on new ring and pinion gears. Going with 4.10's.
  6. White Trash
    Eastern WA
    If you really want to get it rebuilt then groovy but 4.10 is a super generic ratio in 4wd so they are available under $50 most of the time.
    Blacklightnin55 likes this.
  7. Blacklightnin55
    Louisiana
    1990 Ext-cab
    Where can you get them at that price
  8. White Trash
    Eastern WA
    I'm on several 4x4 message boards and I was into wheeling for many, many years so I have contacts all over the area. 3rd members are cheap and plentiful.
  9. fred heath
    fred heath Addict
    Raleigh, NC
    The 2wd, 8" axle (GO82) comes with standard 4.10 gears. (4 cyl). Not sure if they changed it for the V-6.
  10. Mattyp902wd
    Mattyp902wd Newbie
    Vancouver island
    90 xcab
    My v6 has 3.73 or something like that, most of my driving is in second gear, should prob swap it out
