79 hilux sr5 2wd brake issue
Discussion in 'Maintenance/Repair' started by jfranco93, Sep 13, 2015.
  1. jfranco93
    jfranco93 Newbie
    Just bought a new to me 79', still sitting at my friends house due to brakes acting up.
    Just replaced master cylinder with a new one from autozone, bled all four cornera, did bench bled the MC before install.
    If I pump the pedal I get pressure but as soon as I let the pedal out pressure desapears. There is a valve under MC does any know what that is ? And what it does
    Thanks in advance
  2. jetas
    Are there 3 lines coming out of the valve?
    Change the vaccum line from the engine to the booster
  3. jfranco93
    jfranco93 Newbie
    2 lines to the valve from MC and 3 out.
    The vaccum line is just for the booster isn't it
  4. jetas
    The little valve i think just splits the fluid front to rear.
    The vaccum IS for the booster but it affects braking and pedal feel if theres a leak or no vaccum.
    might need to bleed the brakes again
  5. jfranco93
    jfranco93 Newbie
    The engine is off...so pedal should be hard but like I said I can pump the pedal and get the pressure up.... am going to try and bleed the calipers again
  6. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    Maybe the booster is bad?
  7. jfranco93
    jfranco93 Newbie
    The booster has no effect on brake hydraulic pressure.. I plan on deleting the booster anyway
  8. jfranco93
    jfranco93 Newbie
    So am just going to update this thread with the fix... I ended up getting a new master cylinder from autozone for the price of a rebuilt one ( don't ask me how). Flused and bled the system and my brakes came back.
    $12 dollar fix :)
    Erick561 likes this.
