4speed to 5speed swap
Discussion in 'Engine/Drivetrain' started by Angel, Dec 14, 2009.
  1. Angel
    Angel Member
    Orlando
    83 pick up
    :confused:To be honest I’m clueless on what I’m doing. I need info on if and how to swap from a 4 speed to a 5 speed transmission. I do know I have a W42 4 speed transmission, the number on the casing 33111-20091, and the number on the extension housing 33141-20090. I would like to just bolt a 5 speed without any mods. Not sure what any of the number mean. :confused:
  2. 79 flatbed
    79 flatbed Member
    wellington, new zealand
    79 rn25
    hey man, what truck you running? w series gearboxes are interchangable with k series gearboxes( with steel casings not alloy) the bell housing patterns are the same and with minor mods to the gearbox mounts you wont even have to chop the driveshaft. go on wiki-pedia and search w series gearboxes, ive got some information somewhere will find it and and post it
  3. Angel
    Angel Member
    Orlando
    83 pick up
    83 pickup with a 22r and 4 speed transmission with a short bed
  4. Angel
    Angel Member
    Orlando
    83 pick up
    will a w55 work?
  5. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    W55, 56, 58 will fit... You will need the tranny mount bracket from the 5-speed...
  6. Angel
    Angel Member
    Orlando
    83 pick up
    is there any down falls on the w58?
  7. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    It's the most desireable one in most cases. Has a decent first gear and the tallest 5th. The 55/56/58 are lighter and stronger than the old 40/50
  8. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    ive heard that the cast cased 40/50's are stronger and hold up better to large power then the early 58's. by early i mean non supra pre 86, the later 90's ones are supposed to be really strong.
    but dont take that as they are weak trannys, any of em should handle anything a 2xr can throw at em.
    imho the only down fall for a w58 in a truck is the car gear set, if you ever need to tow something, your not quite geared right. still works just fine tho.
    and BillyM on www.celica-gts.com sells a awesome shifter bushing, snap on ratchet accurate shifts, and zero slop. F'n awesome i tell ya, awesome. in fact i bought 5 sets:verdict_in:
  9. lucky_brew
    lucky_brew Member
    i swapped my 4 speed for a 5 speed. bolted right up. not sure which tranny it is though. all i know is my truck is an 83 hilux and the tranny was from an 83 sr5 hilux.
    good luck.
  10. Angel
    Angel Member
    Orlando
    83 pick up
    What year and model vehicle could I take a w58 tranny from, with the least mods?
  11. standardbyker88
    lynnwood, wa
    81-84ish celica with a 22r. only mod would be the crossmember has to be cut and move the mount pad back 2". stick location and overall length are the same as an 83
  12. Angel
    Angel Member
    Orlando
    83 pick up
    Thanks guys for coming thru, Now it's time to get some work done. I'll let you guys know how it turns out.
  13. Colter
    Colter Newbie
    I'm trying to find a tranny for my 78 chinook it has a 20r. The 4 speed is going bad I'm out of town in it and would like to pull one out of a junkyard. I want 5th but the lowest first gear, is that the w58? And what can I pull it out of and what year? Thanks
  14. AIRICK
    AIRICK Enthusiast
    Northern KY/ Cincinnati Area
    83 Standard Pickup
    Angel, did you have any problems putting that 5 speed in your 83? Which transmission did you get and were there any gearing issues? I've got the same exact truck and I'm thinking of doing the same.
  15. glitchinq
    glitchinq Member
    keep the 4 speed. im probably late to the thread but its a more solid trans
  16. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    LOL "probably late to the thread" he says :D
  17. Colter
    Colter Newbie
    Should I rebuild it or just throw another in? If rebuild where do I buy parts reasonably?
  18. jetas
    W58 probably wouldnt be the best for the chinook. Try looking for a regular truck 5spd.
  19. Colter
    Colter Newbie
    What years of truck tranny 5 speed will marry to my 20r?
  20. fred heath
    fred heath Addict
    Raleigh, NC
    W50. Even swap, no mods necessary.
