2017 Winter Work
Discussion in 'Exterior/Body' started by TRUCK ACTION, Jan 10, 2017.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Has every winter I make some kind of change to my truck & repair anything that is in need.
    This winter I am doing repair to the doors where the old mirror mount holes where as didn't fill as I knew I should have & they where high lighting through the paint a little.
    Ground out & welded up, than body filler, now have sanded out will spot primer today & wet sand the doors & front fenders out, remove the hood & do the same they.
    Reshoot all & lay new flames heaver white pearl to match the bed. IMG_20170109_121235.jpg
    grassfed and Mikerocosms like this.
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Another part of this winter work is redoing the upholstery work I did on the door panels.
    I got a 2nd set of door panels ( 4 Runner) & I'm doing the prework, there are small plastic mounting pins of which screws thread into, these hold the window switches plate IMG_20170110_115822.jpg IMG_20170110_115826.jpg to the door panel, & they break off over time!!
    I cut to fit metal thread sleeves ( 6-24 fine thread ) & glue these in place of the plastic pins!
    Mikerocosms likes this.
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Test fitted the panels & reinforced the pins, wet sanded the doors & fenders will spot prime tomorrow than wet sand out again!
  5. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    What kind of epoxy do you use for those mounting pins?
  6. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I use E-600 to glue in position & than Q-Bond around the base of them.
    Q-Bond is a great product for repairing just about anything !
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Got some more work done, all masked off & prime the areas of work, still have to remove the hood & mask to shoot the fenders!
    Hope to start shooting the bottom areas & the top red areas this coming week,& get two coats of clear on than the flames & more clear.
  8. neonjay
    neonjay Member
    Can't wait to see the final result. What paint are you planning to use?
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Omni from PPG base paint & Shop Line European Clear JCT200/ JH7210 hardener.
    Start cutting with 400 wet paper thru 1500, polish out with 3M rubbing compound ,than polish with Mequiars Ultra Finish, & then Meguiars NXT wax. :cool:
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Slinging paint, got the lower section shot with the Met. Charcoal , will shot the Met. Radent Red today & get a couple IMG_20170127_155727.jpg of coats of clear on tomorrow.
  11. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    IMG_20170131_124833.jpg IMG_20170131_134016.jpg IMG_20170131_124817.jpg IMG_20170131_141139.jpg
    Got the red base & a couple of coats of clear shot, wet sanded out & got the flames laid out, tomorrow I'll put the mask /transfer paper on & shot the whit pearl.
  12. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Looking great! Love the dog flag too.
  13. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    lookig good....woulda looked cool if you painted the bottom red and then did the top half grey. two tone
  14. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    looks good ..
    curious as to what windshield washer and rad overflow tank you have ?
  15. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    They are over flow tanks from Billet Spealities, I machine out the bottom of one to fit in the window washer pump, the other is the radiator over flow. Billet spealities tank.jpg Radiator work-4.jpg
    Mikerocosms and twizted1 like this.
  16. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    120 mile drive up to Sacramento this morning & got my transfer paper, back & got all ready to shoot in the AM IMG_20170203_120457.jpg IMG_20170203_120851.jpg IMG_20170203_122712.jpg
  17. slacker
    slacker Addict
    84-7m-GTE custom
    thanks for the info ...
    I'm looking for something to fit my Twin turbo 3.4L build ..
  18. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    So now close on finishing up this paint work, got the hood based out, cleared & laid the flames on today.
    Now wet sand out that work & shoot 4 or more coats of clear,wet sand again & than the polishing starts! IMG_20170216_123951.jpg IMG_20170216_134308.jpg IMG_20170216_153446.jpg IMG_20170216_160204.jpg
  19. Orlando Muniz
    Orlando Muniz Veteran
    Pflugerville, TX was Sac Town, CA
    89 Toyota Pickup
    NICE! how is that aluminium Radiator holding up? i was thinking about getting the similar one from ebay, just was very unsure of the quality...
  20. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Mine is not like anything on e-bay, custom made by Griffin.
    They claim theirs are all welded & than they coat over all seams with a epoxy of type.
    I had a small leak after a year or so, they made me a new one,no problems& have had for a long time!
    Costly!!!
