1UZ 1990
Discussion in '1989-1995 Build-Up/Project Threads' started by 90DailyDriven, Mar 2, 2015.
  1. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    Got the engine back a couple of days ago. 22r and 4 speed are gone. Same tech who worked on the 1uz took it so he can rebuild it. It's in good hands.
    That gap.
  2. 90DailyDriven
    New Mexico
    Bought a couple of more parts over the week. I have also been busy removing and deleting more emissions crap. I have been cleaning misc. parts of the engine and painted the valve covers to match the intake.
  3. madstriker
    madstriker Member
    Las Vegas, Nevada
    2008 Toyota Tacoma
    Nice build. Good job!
  4. CREETIN247
    CREETIN247 Enthusiast
    Columbus, OH
    86 Std
    Makin good progress yo!! Still debating between doin the same build or bags!! :shrug:
  5. 90DailyDriven
    New Mexico
    Just do both! I want to bag my truck after I'm done with this part of the build. Dont want to bag then the 1uz not fit. Id rather build the truck around the 1uz. But then it won't be my daily...
  6. yotarip
    yotarip Veteran
    Building a fast truck is 100000000x's more fun than a slow bagged truck.
  7. cruuz
    cruuz Newbie
    Pittsburgh
    It's an '80
    ^ x2 I'm with 'rip on this one. Keep it static man
  8. 90DailyDriven
    New Mexico
    Organized the spark plug wires today since they were all over the place.
    passenger side was simple. Not as crowded.
    The driver side that was making me scratch my head. Tried different ways to rearrange them and it wasn't working. After 20 minutes I think I got it.
    This is where I was having problems.
    I also found this while cleaning the timing belt covers. I wonder what the PO was trying to glue together...
  9. Ministock6
    Ministock6 Member
    Lake Mathews CA
    1990 Lucas Oil Regional Ministock #6, 1994 Bagged C-notched and Shaved parts truck turned play toy
    Such a awesome project...! Looking forward to seeing it completed...!
  10. 90DailyDriven
    New Mexico
    While putting on the timing covers I could not find the water pump pulley bracket... might have thrown it away.
    And because V8
  11. 90DailyDriven
    New Mexico
    Mock up of intake. Fuel rail not on the engine yet. Fuel injectors will get cleaned they will also get new grommets, o-rings, and bushing.
  12. Cade01
    Cade01 Veteran
    Eugene, OR
    1973 Toyota Hilux
    I want some of these for my '73 Hilux soooo bad!
  13. 90DailyDriven
    New Mexico
    Truck interior is going to go back in this week. Going to take vacation time from work to get back on the truck... hopefullly.
    This was taken 2 days ago.
  14. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Glad to see you made it through last weeks "storm of the century". You gotta clean up all that wiring. Once you do it'll look awesome.
  15. 90DailyDriven
    New Mexico
    That storm had the area around my workshop flooded for a couple of days. The wiring is going to be a pain in the ass since I already forgot why I cut some wires.
    I hit the junkyard and 2 hours later.
    I grabbed the upper and lower oil pan, Oil baffle, pickup tube, oil sensor, dip stick w/ tube, oil filter mount, and both exhaust manifold w/ oxygen sensors and heatshields
  16. 90DailyDriven
    New Mexico
    Checking fitment on exhaust manifold. Of course the drivers side did not fit properly because mine has air injection. Will have to grind it down a bit.
  17. 90DailyDriven
    New Mexico
    More pictures of slow progress.
    exhaust manifold grinded down to fit around the air injection.
    Upper oil pan installed.
  18. 90DailyDriven
    New Mexico
    Rear sump on. Just missing a stud or long bolt to go through both pans to the block.
    Oem oil filter. These are now 90915-YZZD1.
    Toyota block off plate from a 1990 van. Exhaust manifold block off plate slightly cut to delete the 1uz pipe that sits behind the engine which bolts from the exhaust manifold to the intake manifold.
  19. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Awesome. I can't wait to see it dropped in and running.
  20. 90DailyDriven
    New Mexico
    I can't wait either. I miss driving this truck.
