1UZ 1990
Discussion in '1989-1995 Build-Up/Project Threads' started by 90DailyDriven, Mar 2, 2015.
  1. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    I grabbed two fan controllers from mishimoto and combined them to work off of the same temp gauge. One will turn on at 170 and the other at 200 degrees. I can change the range with the turn of a knob. I took @Mikerocosms idea and stuffed this box pretty tight.
    This is the finished product of the fans. Had to cut a couple of tabs off the front grille in order for it to fit.
    Idler pulley delete. I will also remove the fan bracket later. It will clean up the timing cover a little bit.
    I thought the rear main was leaking due to the whole underside being covered with oil or grease. Truck has been sitting for a while now and the leak is easy to spot. Now its only being covered by spider webs.
    Mikerocosms likes this.
  2. Hawk44
    Hawk44 Newbie
    Love your built, keep it up
  3. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Awesome fan controller box fitment. ;)
  4. 90DailyDriven
    New Mexico
    Thanks for the idea :lol:.
    First fan turns on right at 180 and the temps don't get high enough for the second fan to turn on. I'm sure it will work fine in the summer.
  5. 90DailyDriven
    New Mexico
    Finally put this together. The mount for the remote oil filter is already welded to the frame. Now to find some time to install them. This will make oil changes a breeze in the future.
    Mr.Mini_4.0 and Mikerocosms like this.
  6. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Hmm, I wonder if that's something I can do to my Tacoma. I hate where mine is located. It's the only Toyota I own that has an oil filter that is difficult to get to.
  7. 90DailyDriven
    New Mexico
    Its possible. The adapters are a plate that spins on to the original filter location and then use the remote filter bracket.
    I bought the filter bracket and fittings locally from ricks performance.
  8. 90DailyDriven
    New Mexico
    Belltech rear drop springs just arrived.
  9. 90DailyDriven
    New Mexico
    I thought i would share this picture with you guys. This is why i put a bag over my filter when i park the truck. The dust just gets everywhere.
    Mr.Mini_4.0 and Orlando Muniz like this.
  10. mutantcolors
    mutantcolors Enthusiast
    What the hell, do you live in a desert? I never get that dirty when I drive a hundred straight miles of dirt road.
  11. 90DailyDriven
    New Mexico
    Yes i do. We had some high winds last week
  12. 90DailyDriven
    New Mexico
    I noticed oil on the floor over the weekend and that the oil pan is leaking again. I beleive its from the oil pan being really close to the front crossmember and rubbing on engine movement.
    In order the reseal it I have the lift the engine maybe 6 inches to clear the oil pick up tube. So to avoid this in the future I am modifying the front crossmember cutting and reinforcing the torsion bar supports.
    Progress.
    Engine won't come out untill I have some time off from work. So maybe a couple of weeks...
  13. 90DailyDriven
    New Mexico
    When I get time to work on the truck I turn pandora on and get into work mode and never think to take pictures for you guys. The engine was pulled to reseal the oil pan and new front crossmember installed. Next time the oil pan needs to be resealed i wont have to pull the engine.
    Drop springs in
    Oil filter relocated.
    Removed heater and ac cores.
    Mr.Mini_4.0 likes this.
  14. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Looking good!
  15. 90DailyDriven
    New Mexico
    Welding a couple of 1" flat stock behind the steering wheel to mount this cheap rpm gauge from amazon. Its in front of the speedometer and the MPHs are just visible.
    And then some progress on the trans tunnel. I have already covered the top and back half is done.
    Mr.Mini_4.0 and 4age-turbo like this.
  16. 90DailyDriven
    New Mexico
    Havent touched the truck but I did pick this up for $600. Guy said it cranked but did not run. I showed it gave the guy the money, he signed the title and 30 minutes later i drove it home. Turned out to be the fuel pump hose that bursted.
    yotarip and YOguyDA like this.
  17. mutantcolors
    SC300 or 400?
  18. 90DailyDriven
    New Mexico
    Its a 1993 sc400.
  19. mutantcolors
    Nice. I was gonna buy a 92 SC400 for whatever I could talk the guy down from $900 for, but the interior was absolutely ravaged. If he still has it when I'm ready I'll just buy it as a parts car.
    90DailyDriven likes this.
  20. Orlando Muniz
    Orlando Muniz Veteran
    Pflugerville, TX was Sac Town, CA
    89 Toyota Pickup
    That's awesome! Great find!
