Hey guys, this is my first post! I just got a 77' SR5 and I managed to scoop up 5 wheels off of an old Jeep Cherokee. Everything I read online () says that they are 4.5 and 114.3.....So they should fit right? Well today I managed to test fit one on the rear and the bolt pattern works, but there is quite a bit of left/right movement before they are tightened down. Is it just a case of needing larger bolts? I have attached a link to a video that gives an idea of what i'm talking about. Any help is appreciated, thanks guys/gals! https://youtu.be/oAsuV_ndKdU Don't worry, I wont drive around like this, I'm just test fitting them!
I should add, that once I tightened down the lugnuts the wheel was nice and tight. But there's no way i'd feel comfortable driving around with these, haha. http://i299.photobucket.com/albums/mm295/Mctweed123/77%20Toyota%20Hilux/20151004_140639_zpsfsx8kfuq.jpg
Alright, thanks for the quick response! I figured that was the case, and am definitely replacing the lug nuts. I'm just concerned about that left/right movement prior to tightening them down.
The lugnuts aren't ideal but the can be driven on if you'd like to. What you need for aluminum wheels is a "bulge" style lugnuts since it won't possibly dig the hex portion of the nut into the aluminum. The side to side play is perfectly acceptable since the nuts do the centering.
yeah, what you need on those are "acorn nuts". They do the centering as was stated previously. The other issue you are having is that center bores of the wheels do not match the hub-centeric rings on the axles/hubs. When properly matched the wheels will center up during installation. This is helpful but not critical in alloy wheel applications that use an acorn nut design. Its more important for wheels that use a shank style lug nut.
