300ZX wheels
Discussion in 'Wheels/Tires' started by one2sho, Feb 27, 2017.
  1. one2sho
    one2sho Newbie
    Patterson, Ca.
    1987 Toyota Xtra Cab SR5
    Hi, I have a set of 300zx wheels I want to run, do I need a spacer or not? If so, what size should I use? I have 4wd fenders on the front w/ Cali bed, I don't want them to stick out, need them to TUCK.. Any HELP would be greatly appreciated.. Thanks..
  2. DMC
    DMC Member
    Might wanna give a little more info about the wheels you're trying to fit. Rim size, offset, tire size, etc...
    I'm sure someone will chime in and help you out once you they have the info.
  3. ace89
    ace89 Member
    vallejo,ca
    86 xcab sr5 turbo
    They will tuck
  4. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    do some burn outs. see if they tuck.
