A/c idle need help pls
Discussion in 'Frequently Asked Questions' started by Yotaman, Mar 27, 2013.
  1. Yotaman
    Yotaman Newbie
    Sorry guys I need help again can someone pls tell me where the ac idol is located on my 95 toyota hilux because when I kick the ac on the idle
    Is good but when the truck warms up and I go once I speed it up a little And
    Put it to neutral the idol drops so low it feels like it will die
    Can someone pls help thankyou minis
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Little screw with a spring under it on an adapter thats screwed into the valve cover side of intake. Has a fairly big vacuum line going to it.
  3. DjMjD
    DjMjD Enthusiast
    Las Vegas, Nevada
    93 base
  4. Yotaman
    Yotaman Newbie
    What if
    Thankyou!What if I turn it and idle don't pickup when ac is on?
  5. Kirk
    Kirk Member
    Hi I'm having some problem to find how to run my vacuum lines can anyone post some pics of there's so I can see how they should be please.
