just here to get the best suggestions out of members and share my opinions too other than that hope everyone's builds/future builds get done without to much headache With that being said I'm trying to do a 4Runner slammed or drop. I've read "Dcups" forum a lil I'll keep you guys posted Bought this 94 pickup for cheap blown head in the process of rebuilding it sent the heads to get worked a lil should have it back tonight and hopefully running by early morning then the hunt for a 4Runner body begins or should i buy suspension parts first
Slammed/Bagged 4-Runners look very bad ass, I seen many at car shows over the years . Do all your researcher & start collecting parts,do it once & do it right!!!
Yea that's what I'm trying to do, get it done right the first time hopefully parts and funds come in easily
So you're putting a 4runner body on a truck's chassis? Is this the correct way to do this for a drop 4runner? Wondering why not just drop the 4runner chassis instead of dealing with body mounts and gas tank location on a truck's chassis? Or is it to take advantage of the 2wd front suspension setup vs 4wd/prerunner setup that a 4runner would have come with?
More pain in the ass work to lower the 4Runner chassis. Plus no one makea lowering parts for a 4runner
Having trouble with the truck so 22re head gasket changed and etc had it at TDC and Distributor at about 1 o'clock it cranks healthy but won't turn over?
Its less work to do a 4runner body swap on to a 2wd chassis then it is to rework the 4wd chassis to make it even remotely close to the ground.
If you see this truck around in alaska.its mine.im in anchorage from da 808 too.if you need help with that project.let me know.maybe I can learn something....
Sounds good Bradda I'll keep you posted on the build haven't been able to put it back together hopefully gets done tomorrow
